Kenmore HE5 Electric Dryer Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does F70 flashing mean? - Kenmore HE5 Electric Dryer
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Nov 23, 2010
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629094
Points
28464
The F70 is an internal control problem. It can be caused by a failed central control board or an interface problem. The way to determine which part is bad when the error occurs is as follows:
  • If the error occurs when the machine is running then the problem is the interface.
  • If the error occurs when the washer is not running the problem is the central control unit.
1helpful
Code f70. What does it mean for whirlpool cabrio
The Cabrio Washer Error F70 code is the same as the OL code: This code stands for overloaded which means the control has recognized that the load in the tub is to much for the machine to handle or there is friction on the drive system not allowing the basket to disengage.
What does F70 mean on a front load dryer?
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
F70:
No communication between the electronic control board and the user interface control board assemblies.
Unplug the dryer. Check the wire harness connections between the main electronic control board and the user interface control board assemblies. If the connections are sound, have a technician diagnose the cause of the communication failure. The main electronic control board and/or the user interface control assemblies might need to be replaced.
1helpful
What does f70 overloads means
Sounds like either an amp problem or a fan problem. Either one can send a F70 code. Check and see if the rear fan is turning freely, it might just be dirty and can't spin easy
The panel is flashing a F70 problems what does this mean
Hi, F70 means that the dishwasher senses the motor running even though control board is not telling it too. Here would be the reasons for this 1) There is water in the base pan so it has flooded and is trying to remove any water remaining in the tub. 2) Your control board relay is stuck.
If you want to to check for water in the base, you need to uninstall the unit tip it on it's side and remove the 4 screws on the bottom of the base pan. If you remove the pan and see water you need to determine where it's leaking from. If not you need a new control board.
Jun 28, 2011 • Dishwashers
2helpful
What does the fault F70 mean for a Miele G 1534 Sci dishwasher, please?
hello,
The code is an indication of a problem on the washer
F67 means the input voltage on the microprocessor is incorrect. Code F70 indicates a problem with the water temperature sensor circuit. F76 means the NTC temperature for the cold water valve is over the limits.
thanks.
Oct 26, 2010 • Dishwashers
What is f70 mean
Hi.
F70 is an electronic problem. I expained detains in the tip below.
The tip applies to whirpool built appliances like this Kenmore:
F70 and F71 are two logic board error codes that point at a communication error between the main log
F70 mhwe900vj00
What is f70? is that an error code? there is no f70. there is an f07 code.
http://www.repairclinic.com/0078.asp
there it will tell you what f07 means and what to check
but if i am way off tell me what exactly you want to know thanks
3answers
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
What is F70???
F70 means Blown Internal Fuse change the internal fuse and that should solve the problem if not you may have to change the output
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
