The CE-5330 only works with SD cards up to 2GB in size. It will not work with higher-capacity SDHC cards.The CE-5330 only works with SD cards up to 2GB in size. It will not work with higher-capacity SDHC cards.
You can't post conmments that contain an email address.
The phone can handle up to 32 Gb micro SD cards, so I think the format is not good. Try formatting the SD card in your phone, to make sure the format is what your phone can work with.
If you can't use the card, because the phone does not let you format is, try formatting it in a PC, using an external memory card reader. Us format FAT32.
The manual indicates using memory cards of size 8 to 128 MB, so this is an early SD memory camera, following the original SD standard. Do not try SDHC or SDXC cards. The camera will support a 1 GB card. It *might* support a 2 or 4 GB card, but since this is a 2 Mpixel camera, a 512 MB or 1 GB card will allow you to save thousands of jpeg format pictures.
the problem can be solved.For the video not to be able to play might be due to the video file being corrupted or the memory card was not really formatted properly.
You can format the memory card again and try transferring the file into the memory card.If it does not work, try and use another device to format it.
If still it does not respond properly, then the memory card is corrupted and it needs to be replaced.
i believe they are only capable of 2 gig, get a brand new 2 gig for around $7 online, and the device should recognize it, i have the brand name kingston, my problem now is, i cant sync music, if u figure that out, let me know
