SOURCE: What does a fault F01 signify on a Hotpoint Ultima
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
SOURCE: hotpoint ultima 1200
Kirsty - There could be an item like a hair clip Jamming the pump impeller. Or then it can be only a blockage in the filter or in the waste pipe or if the waste is connected to your sink drain check that the blockage is not there - either in the end of the pipe or in the sink connection.
Try disconnecting at the sink, holding the waste pipe into a bucket see if it will pump out then. If it does then the problem lies in the sink plumbing - if not then it lies in the machine.
If the pump and filter and hoses are definitely clear you could have a Pump, PCB or wiring fault. Hope this helps.
SOURCE: I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Thanks.
SOURCE: I bought my Hotpoint WMD960 Oct 2008 14
Fault f5 is indicating pressure switch jammed on full.
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps.
