Many of these sets had problems with bad picture Tubes--they use a red,
green and blue crt. Most commonly the blue gives troubles--The tubes
are now only available on a rebuild basis--usually not worth doing as
the cost is very high.
You may have a bad blue picture tube but
there is a way to deal with this first----the set has a black plastic
block with six controls---three are Focus(red,green,blue) the other 3
controls are Screen controls(red, green, blue)
Someone has to
remove the entire piece on the frontof the set below the screen(usually
a plastic part) most of the time it is secured with 3 screws on either
side of the set in the back; once you remove the screws the entire piece
should pull out(pull from right to left(it will not fall off or come out
easy--it is held in with several large plastic pegs) With it removed
there is an inspection plate with 4 screws-----the screen/focus block is
behind it.
You need to look very closely at the block to
identify the focus versus screen controls----one row left to right will
be marked Focus and the other row left to right will be marked
screen------YOU need to locate the Blue Screen control(they are black
like the block) With the set on(be careful) go to a
videoinput
with nothing connected---if you see a blue screen as well as the input
number turn the BLUE SCREEN CONTROL SLOWLY TO THE LEFT UNTIL THE BLUE is
gone.
If this cures the problem you may only be buying yourself
some time----if the blue picture tube is bad sooner or later this
trouble may return----I have seen sets where this was adjusted and the
set worked for a year or more with no repeat of the trouble----replacing
the blue tube would likely cost you 400 -500 parts and labor.
I do this here for free so if this has helped you rate this solution.
SD TECH
