Comet GXD2527G Pressure Washer Pump Logo
Posted on Oct 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pump oil seeps out of its fill cap. - Comet GXD2527G Pressure Washer Pump
Anonymous
Level 3:
  • Master 760 Answers
  • Posted on Oct 10, 2010
Anonymous
Master
Level 3:
Answers
760
Questions
0
Helped
491048
Points
2276
More than likely you have water leaking into your oil, making the oil float on the top and out of the vent. Eventually you'll only have water, and no oil. Drain oil and replace. You will probably have to replace the seals between pump and crankcase. Only remove front of pump,(brass part) if you catch it in time the bearings in the rear portion won't go out. Do it now before the water wears the pump out. You can get parts for most pumps at www.pressure-washer-parts.com. Or go to www.cometpumps.com Hope this helps.
1 Related Answer
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on May 17, 2010
SOURCE: How full and with what oil to fill pump vent.
Any pressure washer pump should be no more than half full. The reason is if you fill it completely up when the piston strokes it will blow the seals out of the pump. Usually there is a sight gage on the side of the pump. I will look your model up and see what I can find as far as quantity for the pump. I won't be too long just read the 2nd response and please do not rate this one. I will get back to you ASAP.
Kelly
2helpful
What type of oil does remington 3.5 electric saw uses?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 (30 weight non-detergent oil) with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
1helpful
What type of oil should use?m/n 10852601
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
FILLING OIL TANK
1. Remove oil cap.
Your manual goes from page 6 to page 14. This one is very good.
Lou
2helpful
What type of oil do I use in my remington 16 inch 3.5 hp electric chainsaw?
FILLING OIL TANK
1. Remove oil cap.
Lou
Thank you for using FixYa.
What kind of oil uses on remington 14" electric chain saw?
FILLING OIL TANK
1. Remove oil cap.
Lou
What type of oil does it need
Bar and chain oil. It is SAE 30 with a some additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (page 9 (edited)).
FILLING OIL TANK
1. Remove oil cap.
This is a Remington OM
http://shoppingcart.msservicecompany.com/msservice_net/product_files/107624%2001/107624-01-EL-8-OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
1helpful
Is it bar oil that needs to be put in the resevoir
Yes; bar oil is SAE 30 with a some additives to make it adhere to your bar and chain. An excerpt from a Remington manual follows:
From your OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
This is from a Remington OM
Lou
2helpful
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
Lou
What type of oil do I use for pole saw?
Use bar and chain oil (bar oil is SAE 30 with an addative to make stick to the bar and chain) available at home centers and hardwares. Excerpt from a Remington OM follows:
“FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil.
Note: For temperatures below 30°F, use SAE #10 oil.
For temperatures above 75°F, use SAE #40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.”
Lou
2answers
Need to know don't want to blow my saw up
40w will work
the two cycle oil sold in stores has a green dye mixed with it to let owners know it is for two cycle engines.
it is all 4ow oil
2helpful
2answers
What type of oil is used in the remington 16" chain saw?
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain):
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH Lou
Top Comet Garden Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Comet Garden Expert? Answer questions, earn points and help others
