In the 1960's, Riccar made a heavy duty 777 sewing machine. Riccar made machines into the 1970's. The headquarters appears to have been in Chicago before it moved offshore. Value of the machine? Maybe $100 if it worked. Parts might be found or salvaged from machines used for parts. However, here is a Riccar shop in South Carolina:
I would be doubtful regarding offers of a manual for sale for this online unless at minimum it was attached to a brick and mortar store in business (and even then might query the local Better Business Bureau).
You may be better off going to google and search "riccar 2910 manual" That way you can follow their detail dorections rather then someone elses and it confuse you. Usually the PDF versions have pictures with it :-)
Generally, this is because your needle is bent, even if you can see that it is. It only has to be the slightest bit bent. Try changing the needle and see if this fixes the problem. 9 times out of 10, it does.
