20 Most Recent
Riccar R651 Mechanical Sewing Machine Questions & Answers
Looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
My riccar 707 is stuck in reverse. stitching,what is the. problem.?
Most machines have a button that is on the front of the machine. It is located on the front with machine with the stitch selections. The button is pushed in. Push the center button again and if that doesn't work, push the outer edge of the button and it will release.
