F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Press "end of cycle" button for over 5 seconds, the child lock comes off. Press it again and the child lock comes on, this works for Hotpoints, you could try, no harm. If it works, pl rate me.
