I'VE CHANGED THE BATTERY, PLUGGED IN THE WIRELESS CONNECTOR, BUT MOUSE WON'T WORK. WHAT DO I DO
There's also a connect button on the USB connector. Plug the connector in and press the connect button underneath until the light flashes. Release the button and click the connect button on the mouse until the USB light is steady.
Solution #3 was it for me. I can't believe they put those tiny little connect buttons on that usb stick and the mouse both. I did it and its working great! thanks so much!!
There might be a other problem to mine does not work so i took apart the usb reciver and found that a wite wire had been broen becouse the reciver moves up ad down so much it broke the wire
I have the same problem with the same mouse when i pres the connect while the stick is inside it blinks and the pointer moves but not so good, when the blinking stops and its green the pointer doesnt move again... !!
?· If you plugged into the mouse port, restart your computer manually.
?· If you plugged it into the USB port you may begin using it.
?· When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven
I tried clicking connect on the usb thing but it still didn't work.
i connected mouse to laptop but when i try to use tHe mouse it dosent move
