20 Most Recent
Targus PAWM001U Mouse Questions & Answers
Driver download
sir i have an problem in my pc the problem in my pc is audio drivers so plz hlp me
thanks
waseem khattri
My lap top wont recognize
Hi! Gheng here, what type of mouse your using? if its Ps2 or USB try to unplugged and plug it again then restart your Computer, if it has no changes.. i thnk ur mouse has a problem try to get another one.. Enjoy...
Il mio pc non mi installa i driver del mouse
Se il tuo mouse ? stato fornito con un disco di installazione, allora prima di tutto scollega il mouse, fai un reboot del PC (Spegni e riaccendi), prova a installare i programmi forniti con il CD e poi collega il mouse solo alla fine (Eventualmente prova su una porta USB differente).
Fammi sapere se vedi dei miglioramenti.
Saluti
How to install batteries in
On the black cover, press on the Targus label - to release the latch - then slide the cover backwards. It's a little tight but the cover should come out. You'll need to (2) AAA batteries for replacement. Cheers
I have model # PAWM004
On the black cover, press down on the Targus label - to release the latch underneath - then slide the cover backwards. It's a little tight but it shoud come out. I did it just a minute ago. You'll need two (2) AAA for replacement. Cheers.
