20 Most Recent
Targus USB 2.0 DVD/CD-ROM SLIM EXTERNA DVD Drive Questions & Answers
IGI play
no d3d drivers with hardware acceleration found
The drive is not registered with my machine after I connect it.
u dont have any specific drivers that came with the Targus dvd?
..mabe the generic driver is not exepted!
..or ur usb port is not configured properly!
...do u have usb 2.0!
...did u tried on other ports!
...try to force usb 1.1!
...last step: in bios, try to putt usb dvd , or usb , (or anything similar), to boot from, (make sure u have a proper disk inside the dvd.)
if it worked (and its not simple, u need to make many tries) , then its driver problem, and in xp pro, every thing can be fixed ;)
gd luck
Targus CD/DVD does not show in directory
try to use another usb cable for your external dvd drive>>>> then if it's not working again try to check the bios setup if the optical drive is enable. if the setting is disable please change it to enable>>> if still not work back on where did you bought it>>> maybe it is defective...
D3d
Install DirectX, it can be found on CD with game or downloaded from http://www.microsoft.com/games/en-US/aboutgfw/Pages/directx10.aspx
How to open a Targus Chill Mat Pad AWE61US N2953
Without specific details about the type or model of the mat you're referring to, it's challenging to provide precise disassembly instructions. However, I can offer some general tips that might help you access the inside of the mat for cleaning without causing damage:
- Consult the Manual: If the mat came with a user manual or assembly instructions, refer to these documents first. They often contain disassembly guidelines or tips for cleaning.
- Look for Access Panels or Fasteners: Many mats or fitness equipment have access panels secured by screws, clips, or fasteners. Carefully inspect the mat's exterior for any visible fasteners or panels that might provide access to the inside components.
- Check for Removable Parts: Some mats might have removable parts like covers or casings designed for cleaning purposes. Gently try to detach these removable components, following any instructions in the manual or indications on the mat.
- Contact Manufacturer Support: If you're unable to find a way to disassemble the mat safely or if you're concerned about causing damage, consider reaching out to the manufacturer's customer support. They can provide specific guidance on disassembly and cleaning for your particular mat model.
- Online Resources: Look for online resources such as instructional videos or forums where individuals might have shared tips or experiences on disassembling and cleaning similar mats.
Always approach disassembly cautiously to avoid causing damage or voiding any warranties. If you're unsure or uncomfortable about disassembling the mat yourself, seeking professional assistance from a technician or contacting the manufacturer for guidance might be the best course of action.
