Technics SL-1200 Turntable Logo
Posted on Sep 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am in need of 2x technics turntable plastic covers. where could i find and how much each?
Styluscity
Level 2:
Champion:
  • Technics Expert 271 Answers
  • Posted on Sep 13, 2010
Styluscity
Technics Expert
Level 2:
Champion:
Answers
271
Questions
0
Helped
94529
Points
381
Hi, We have dust covers in stock for SL1200 and SL1210. If you are in NZ the price for a pair is $195.90 NZD. [email protected]
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Dust cover falls down
You'll have to flip your turntable upside down on a pillow or beanbag, remove the feet & all the screws including the harder plastic underside to get to the hinges where by which you can estimate whether there was wear & tear & needs replacing or whether it was a simple fix by just tightening up the screws that hold the hinges in place.
Our Technics SL-1200MK2 has issues with the direct drive. It does not spin at a constant speed. When stopped, it does not stop immediately. What can be done to solve this?
To adjust stopping speed you'll have to remove the plate by pulling it up. Then there is a plastic cover that has some screws, remove the screws and remove the plastic cover, you'll find a variable resistor that reads something like brake. Adjust it to the left or to the right with a screwdriver and see at which position works best.
To solve the constant speed problem you'll have to replace the pitch regulator.
Go to any panasonic/technics service and buy the pitch. If you have a bit of soldering skills you'll be able to replace it by yourself. You can access the pitch regulator unscrewing all the screws under the device and then removing the cover.
Hope you can solve the problem!
2answers
My 1210s will not turn on as if there is no power going to them,there is, and i have changed the plug fuses! any ideas?
Faulty switch? If all else fails go inside! Often from the underside of the turntable and see what you can find.
Plastic top for technics 1200 mk2 turntable
Hi, What do you mean by this pls, you need a new top or how do you fix a broken one?
Thanks Mark H (superstar DJ)
I need a replacement lid/dust cover for my turntable technics SL BD22; Can I get one and from where? and the price aswell please
There are 2 complete turntables up for auction on Ebay. One is at 4.99, and the other is at 9.99. Just do a search.
Do they have an internal fuse? thanks. danny
Hi Danny. Yes they have a fuse. Remove platter, remove plastic cover, main fuse is there
2answers
Its not working and when you press the trigger there is a smell of burn
HI,, IF YOU HAVE EXPERINCES TO OPEN THE TURNTABLE PLS. DO..FIRST TAKE OFF THE PLATTER THEN THE 4 SCREW AROND THE PLASTIC COVER THEN CHECK THE TRANSISTOR Q3 AND Q2  AND ALSO THE ZENER DIODE D3...PLS. DOUBLE CHECK THIS COMPONENTS IF WE NEED TO REPLACE ..AA NEW REPLACE IT.. PLS. DOUBLE CHECK. U
2helpful
3answers
Internal fuse
The Solution:
1. Firstly unplug the decks!!!
2. Remove the slipmatts and platter
3. Unscrew the circular plastic cover (Note: 5 screws holding it down)
4. Upon removing this circular plastic cover you will see a clear piece of plastic covering a circuit board, open it up. Now you will see a two fuses one clear and one stripey. 5. Remove the fuses (Gently poke it out with a pen/screwdriver or whatever) and examine it and see if either or both have infact blown.
6. Bring the suspect fuse/s to any electric/hardware/music type store (or search the net) and try to get a replacment but make sure its the same as the fuse you removed!!!. A T250 mA fuse(clear) an a T1A Fuse (stripey) are stated in the Technics user manual.
7. Now get the new fuse and gently snap it back in to the silver holders.
8. Replace the clear plastic circuit board cover.
9. Screw back the the circular plastic cover (Note: 5 screws holding it down)
10. Replace the Platter and slipmats
Internal fuse
remove platter remove plastic cover main fuse is there
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
