20 Most Recent
Technics SL-DZ1200 CD Player Questions & Answers
I was djing at a night club and there was a little
As a DJ myself, I have seen that before. On a night that the equipment will not be used, UNPLUG ALL CABLES AND POWER, then use an eyedropper to drip a drop or 2 of water on the spindle and manually spin the table a few turns., wait about 5 minutes, then drop a couple drops of rubbing alcohol and again spin the table. Wait a couple hours or over night, and follow with a couple drops of oil. NO MORE THAN 3 DROPS OF ANY OF THESE!!
6/2/2017 7:04:37 PM •
Technics...
Answered
on Jun 02, 2017
Megapro dvd karaoke player
my mega pro 100n was not able to play or open what will i do pls help me my face book account rodel adriatico
1/5/2017 4:36:45 PM •
Technics...
Answered
on Jan 05, 2017
I have a Technics CD changer SL-PD867 it will not play re writable disc's any other disc ok
Not all CD players can or will play CD's burned in a PC. Sometimes the CD player is to old, so not compatible with these CDs. Sometimes the player just does not play these CD's, because of rights protection.
A CD burned in a PC is less reflective than an normal music CD. Normal CD's do have a metal coating and are highly reflective. Burned CD's have a dye, and where the laser burned the dye, it only changed colour. Making it less reflective.
All modern CD playes should be capable of playing CD r's. But the player that is really compatible, is labelled CDr and CDrw compatible.
5/23/2014 4:27:23 PM •
Technics...
Answered
on May 23, 2014
No disc display
This can be caused by many hours on the unit or a bad solder joint on the PCB. It will need to be seen by a repair Technician.
9/24/2012 1:14:48 PM •
Technics...
Answered
on Sep 24, 2012
Technic sl-dz1200
I had the same problem. Replacing the sensor is not gonna help. it is a focus problem. I had to fold a small piece of paper and put it under the sensor to raise it up alittle then you screw it in. The size of the paper you will have to figure out for yourself, but it will help u fix your problem
7/13/2012 8:07:54 PM •
Technics...
Answered
on Jul 13, 2012
Unit has no display and platter spins when turned on
The problem is in the microprocessor ic, it controls selectors, display and mechanical devices. Did you have a recent thunderstorm? which would explain why it is none functional, this is a long shot, unplug unit from wall receptical and any other wires that are attached, now press and hold power for 60 seconds to drain residual voltage in attempt to reset the processor, if this fails cheaper to replace player.
6/7/2012 1:03:35 AM •
Technics...
Answered
on Jun 07, 2012
