20 Most Recent
Technics SL-BD22 Turntable Questions & Answers
I have just a basic belt drive turntable and the
Hi There.
If the belt falls of the platter, it might be an indication that the belt has stretched and is now too large. Or maybe it just fell off for any other reason.
Remove the rubber mat, and pull upwards on the platter to remove it. Sometimes there is a small "C" clip on the center spindle that has to be removed first. (use a small flat screwdriver to remove)
Turn platter over, and put rubber belt around diameter ring on underside of platter. It should be snug, and not fall off when you turn platter over.
Put platter back onto turntable, and spin by hand until you see the motor shaft through one of the holes in platter.
With a pair of tweezers - or crochet hook, put belt over shaft.
You're done.
Put back rubber mat and give it a try.
Good luck,
Fred
PS: If there was a "C" clip, you can re-install it - or throw it away.
The volume on technics SL-BD22 turntable will not turn up and stays at one volume
Since the turntable itself doesn't have a volume control the problem is with the amp it is connected to. It should be connected to an amp with a dedicated phono socket. It's no use connecting it to a tape or aux or CD socket. These sockets do not have a built in pre-amp for the magnetic cartridge. If your amp doesn't have a dedicated phono socket then you can buy a Magnetic Cartridge Pre-amp that will plug into a tape socket etc on the amp and have the deck plugged into it. If plugged into a none dedicated socket though you can hear it, the volume will be very low compared to other sources. If you have got it plugged into a dedicated phono socket and the volume is still low, then the internal built pre-amp inside your amp for the deck has failed and will need to be repaired. The pre-amp failure will not effect any other functions of the amp.
Tehnics sl-bd22 noisy motor what to do?
If the bearing is worn to the point of a rattle and a small amount of silicone oil won't stop it, then it should be replaced or the motor replaced. These bearings are normally lifetime impregnated with lubricants and can sometimes dry out with use and somewhat seize up causing what may sound like a rattle. If the motor shaft has worn down enough at the bearing point, then a rebuild or replacement is in order.
The tone arm will not drop on our Technics sl-dd33 turntable.
Have you left the tone arm lift in the up position?
If not: At the end of a record the mechanism lifts the tone arm, returns it to the rest, lowers it and switches off the motor.
It the motor has stopped too early, the tone arm will remain raised.
You can try gently rotating the platter clockwise by hand. This may allow the return cycle to finish.
Stop button stuck one i press start. What should i do?
order the spring from the button and i would also replace the button , it ain't the money. Offcourse will a little bit oil around the button also will do the trickI agree that they are to loose , even with a knew unit.
gr richard
Why tone arm stuck?
Depends on stuck , i think that i see often with you g dj's and then dirt is the problem and no maintenanance , if you cannot use your height adjustment any more, take the whole unit outand try very thin only , WITHOUT a lot of force to gebtle move it both ways , is very gentle stuff and the problem is often that they've pushed it the wrong side. Number two, the hair heater gently warm it 10 minutes(gloves) ans that will do the the trick and whem loose emediatialy clean and use good lubricant(not to thin), but when you wanna buy a table and the heightadjustment is jammed, it is a bad onr.....runnnnn
