20 Most Recent Technics SL-1200M3D Turntable Questions & Answers
Did Technics make a pre-amp suitable for putting between my SL1200Mk5 and a Technics SL-EH790 stack which has no external turntable in socket to the internal pre or power amp, just an aux in thn need
Mail me and i gave you the parts you have to buy for a good self built one, which is way better then a pro-ject phono box s, which i also have and not diy becomes interesting comparing it to 400euro+ hi-fi brand phono amp. Only those hi-fi brands just but chines capacitors in their gear.... sad
8/16/2014 3:21:56 AM • Technics... • Answered on Aug 16, 2014
2answers
I have a technic sl 1200 m3d with a broken tone
HELLO
Have a look at Originlive on the net. They do an armboard which should fit your turntable easily and enable to put a Rega RB250 or RB300 arm on your machine - it will improve audio quality too!
8/16/2014 3:15:57 AM • Technics... • Answered on Aug 16, 2014
2answers
Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
7/22/2014 11:58:59 PM • Technics... • Answered on Jul 22, 2014
Fuse location of technics SL 1200M3 turntable
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
4/4/2014 5:26:54 AM • Technics... • Answered on Apr 04, 2014
Hi, hope someone can help. I've got a Technics SL1200MK5 turntable that I'd like to play through my Technics SL-EH790 Stack. I know that I need a pre-amp to lift the signal to line rate before
Try these sites:http://www.vintagetechnics.co.uk/http://shop.panasonic.com/shop/support-technics-audio-and-dj
1/20/2013 1:35:37 AM • Technics... • Answered on Jan 20, 2013
WHY DOES MY TECHNIC 1200 MK3 GO IN REVERSE IF I HIT THE START BUTTON TWICE?
There is a mod you can do to the 1200 to make it spin in reverse with a double-tap on the start / stop switch - exactly as you're describing. Likely, the previous owner installed said mod. It's awesome, embrace it.
10/24/2012 1:40:43 AM • Technics... • Answered on Oct 24, 2012
The right side of the
The actual source of the sound is the dose, not the needle. The dose is connected to the audio connectors from the rear of the unit with 4 thin wires that go thru the arm.
Most likely one of that wires broke - this is easy to check: just measure the continuity of the wire from the small connector pins at the dose to the RCA connectors. To fix it, because you can't dismantle the arm to replace them, you will need to replace the entire arm. For that buy and follow the service manual
http://technicsparts.co/product.php?id_product=57
7/13/2011 4:40:06 AM • Technics... • Answered on Jul 13, 2011
Serato does not recognise my
serato is a software to be used with an external soundcard it doesnt care what turntables you have. u have to a rane mixer or one that is serato capable in order to use it. then you have to go and link and sync your time codes
5/27/2011 3:13:26 AM • Technics... • Answered on May 27, 2011
The whole strobe light pushes
Superglue works very good for that
3/24/2011 12:43:53 PM • Technics... • Answered on Mar 24, 2011
Own similar SL 1300 Technics turntable and have
It could be a worn drive belt. Lift the platter oof the machine and check your belt. It may need to be replaced
3/18/2011 6:15:06 AM • Technics... • Answered on Mar 18, 2011
The Power switch on to of the strobe is pushed all
Replacement parts can be tough... Open the unit and you will likely find the switch itself has been pushed in too far... POSSIBLY bending a bracket it is mounted on OR sometimes pushing it out of some plastic tabs... If the tabs have been broken, then one uses an appropriate adhesive to hold the switch where it belongs... Use either a contact cement or silicone adhesive.
3/14/2011 4:05:51 AM • Technics... • Answered on Mar 14, 2011
When I connect my turntable to speakers, there is
Try grounding the case of the turntable to the tuner.
12/16/2010 9:17:32 PM • Technics... • Answered on Dec 16, 2010
My technics 1200 mk5 is
There must be a shorted power transistor in the power supply area. Check the voltage output of the transistor to determine which part is having a short circuit.
11/8/2010 4:03:11 AM • Technics... • Answered on Nov 08, 2010
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
7/7/2010 4:22:42 PM • Technics... • Answered on Jul 07, 2010
2answers
PITCH CONTROL PROBLEM
The reset button disables your pitch control and allows the turntable to rotate at TRUE "0" (zero). FYI, these turntables were NOT made for DJing. They were made for radio, studio, and high end home use. They became DJ turntables, because they were perfectly built for the trade. So, the pitch reset button is more of a function best suited for radio stations or a producer who needs to record or play at a true zero speed.
Now, on to your question...
More than likely you just have to calibrate your pitch control. There are various videos on YouTube on how to do this properly. Just do a search CALIBRATING 1200s or similar. FYI, all the Technics SL1200/1210 MK series are the same inside. MK2, MK3, MK5 - so don't worry if you only find videos on calibrating MK2's or MK5s - works the same on all the models.
- TERMiNAL OPTiC
www.DJPROLAB.com
7/7/2010 1:46:43 PM • Technics... • Answered on Jul 07, 2010
I don't know if i should go with the sl 1200M3D or
The only difference is the Mk3 has a pitch lock switch - other than that they are the same.
7/5/2010 3:01:50 PM • Technics... • Answered on Jul 05, 2010
There is not a signal going from the turntable
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
4/18/2010 6:11:57 PM • Technics... • Answered on Apr 18, 2010
Ground wire disconnected on my technics SL-1200 M3D
to any metal part of the frame
10/9/2009 4:22:20 AM • Technics... • Answered on Oct 09, 2009
Technics SL-1200M3D Turntable Logo
29 questions posted
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Technics Audio Players & Recorders
Most Popular Question
technics 1200 mk5
  • Audio Players & Recorders
