Hi i have a whirlpool adp 5540 and about 2 days ago it just stoopped on the last cycle and the button to start it just flashes on and off ... i reset the machine by holdin it and itfinished the cycle.. i let it sit for a minute then put it on a quick cycle... it went for approx 10 to 15 mins then the same problem any ideas how to solve it?
Our machine is a Whirlpool ADP 5540 / 1 WH - When we turn on our dishwasher it ( having previously manually drained it by holding in start button ) it fills again - stalls for a short period and then the light on the start flashes 6 times and there is no further movement of any sort - please assist - thank you in anticipation Our machine is a Whirlpool ADP 5540 / 1 WH - When we turn on our dishwasher it ( having previously manually drained it by holding in start button ) it fills again - stalls for a short period and then the light on the start flashes 6 times and there is no further movement of any sort - please assist - thank you in anticipation
Our machine is a Whirlpool ADP 5540 / 1 WH - When we turn on our dishwasher it ( having previously manually drained it by holding in start button ) it fills again - stalls for a short period and then the light on the start flashes 6 times and there is no further movement of any sort - please assist - thank you in anticipation I am have the same problem.
I've just had a new motor fitted and it seemed to work for the technician. He told me to run it at 70 degree wash for the first few washes, but as soon as pre wash finishes the on light flashes continuosly and it wont move on in the cycle.I've just had a new motor fitted and it seemed to work for the technician. He told me to run it at 70 degree wash for the first few washes, but as soon as pre wash finishes the on light flashes continuosly and it wont move on in the cycle.
You can't post conmments that contain an email address.
My dishwasher isnt working anymore after i cleaned the filters?
i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere? It is a Whirlpool ADP 5540 thanks for your help ****
the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
turn off the water and remove the hose at the rear of the machine. Inside you will find a small wire gauze strainer. This blocks with limescale and debris from the water mains, just enough to reduce water flow below the thresholds..
E1 F8 Whirlpool dishwasher
If F8 E1 or LF (too long to fill) appears in display, it means the washer is taking too long to fill. It's possible the drain hose extends more than 4.5" (114 mm) into standpipe.
Apr 5, 2021
If this is the machine with just a knob for the wash cycles, and one button to start the wash cycle, you will have to replace the timer. There is no reset that I know of.
An F6 fault code - indicated by the green light flashing in sequence next to the start button - is indicative of a water inlet problem.
First of all check that the water tap the dishwaher connected to is fully open. If this does not work check that the feed pipe from the water source to the appliance is not blocked.
If neither of these two things are the problem then you will need to order a new flow meter/ reed switch and this will sort your problem out.
The Whirlpool UK spare part number you'll need is 481241868368 Hope this helps Alex
