20 Most Recent Whirlpool 24 in. ADP6940 Dishwasher Questions & Answers
The start light is flashing. I checked the bottom of the dishwasher and saw a black pipe coming out of the electric motor is leaking.
Is it possible to replace only the pipeline or have to replace the entire engine?
Whirlpool 24 in.... | Answered on Sep 29, 2016
It sounds as if the drain cycle isn't completing. I don't know if the drain and pipes are having trouble or if the dishwasher itself needs to be re-calibrated. I would suggest having a mechanic or plumber come in and check it out. Try all the different cycles so you can narrow down what is wrong.
Elisa Jed ' http://aceplumbing.com/drains-and-sewers
Whirlpool 24 in.... | Answered on Jul 09, 2014
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Whirlpool 24 in.... | Answered on Nov 30, 2012
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Whirlpool 24 in.... | Answered on Aug 09, 2011
Whirlpool dishwasher start light flashes 7 times repeatedly and wont start
The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose.
F6. means "Water valve (WV1) is switched on but flow meter (FM) senses no impulses" (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
Whirlpool 24 in.... | Answered on Jul 25, 2011
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Whirlpool 24 in.... | Answered on Jun 23, 2011
Hello there
F6 error code - The dishwasher can't take on water. Check that the water inlet is properly connected, the stop tap valve is open and that water supply is otherwise available to the dishwasher. Also check for kinks or blockages on the water hose. if all is good than you may have a problem with the solinoid valve for the water or the cycle timer may be faulty and the door switch may be bad or not working properly so
you will want them checked for ohms and resistance if they are found bad they need to be replaced
Whirlpool 24 in.... | Answered on May 08, 2011
Whirlpool 24 in. ADP6940 Dishwasher Logo
70 questions posted
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Dishwashers
Most Popular Question
error code f4 whirlpool adp 8966
  • Dishwashers
