Xerox Phaser 8400 Laser Printer Logo
Posted on Aug 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phaser 8400 printer will not print in color when used with Windows 7, only b/white
Rui
Level 2:
Scholar:
  • Expert 92 Answers
  • Posted on Aug 31, 2010
Rui
Expert
Level 2:
Scholar:
Answers
92
Questions
0
Helped
47542
Points
257
You can download the Print drivers from HERE. Make sure you select the PostScript Driver v5.48.30 or you can as well use the Global Print Driver, which you can download from the same link. Uninstall previous drivers and Install it as a Local Printer. Please be aware that if you are using a Server/Client structure the this instalation should be done on the Print Server.
After all that you should be able to print in colour. As a test print an Image file and make sure you confirm colour is enabled on the printing preferences of the driver. Alternative would be to print a test page from the driver. This will also show you the colour prints.
  • Brad Jones Feb 02, 2014
    After nearly 2 year's I can print in color. Thx
2helpful
2answers
I need to download the Phaser 3116 driver for windows 7 - can't find it anywhere - help?
http://www.support.xerox.com/support/phaser-8400/downloads/enus.html?operatingSystem=win7&fileLanguage=en
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
22helpful
2answers
Driver for phaser 3116 for windows 7
You can download the driver directly from here:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=8400&Xlang=en_US&Xcntry=USA&source=XOG
Just select which version of Windows 7, and the language.
Hope this helps. If so, please rate. Thanks.
1helpful
Phaser 8400 print management
Yes you can. If it is just you printing you can go into printing preference. Then TekColor and click the black and white option. It will force everything printed to be B&W. You can only limit others to B&W if it is hooked up via ethernet with a IP address. Type in the IP address in your internet explorer as you would a webpage. Go to the properties tab then Printing Security Settings and type in a Color Permission pin. Then if you need to give someone access to printing color in the printers preferences on the layout tab click the advanced button, Under printer features there is a color access area that you can type in the pin to print color. If one color runs out it will not continue to print. It can cause very expensive damage to your printer if it trys to print with no ink in the printhead. So to be safe it stops the machine from printing.
Hope this helps.
2answers
2answers
Phaser 860 error code 07.003.45:116163
It is a print head tilt error.
Most likely ink is in the stainless steel pivot block at the bottom of the print head.
Also the printer could have been unplugged and the cleaning blade is stuck to the print head.
Or a cable is binding the print head movement.
2helpful
2answers
Xerox Phaser 8400
There is a flag sensor on the registration assembly that is possibly broken.
3answers
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
