Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system
Cigar 15A- Cigarette lighter
Audio 10A- Audio, remote control mirror
Air Bag 10A -Air bag diagnostics
Stop lights- 15A -Rear brake light, high mounted stop light
ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module
Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch
ABS 10A- Anti lock brake system control unit
ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit
Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch
Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator
IGN1 20A - Ignition switch
ABS 30A- ABS pump motor
TNS 30A- Tail light, license plate light
COOL/FAN 30A- Cooling fan
Cond/Fan 20A- A/C condenser fan
Starter 15A- Start signal , Fuel pump
Blower 25A- Blower Motor
SR/ACC 10A - Ignition switch
Hazard 15A - Hazard and turn signal light
D/Lock 25A- Door locks
ABS 30A - Anti lock brake system control
P/W RH 20A- Power window motor right hand
P/W LH 20A- Power window motor left hand
IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights
IG 2 30A- Ignition switch
IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector.
O2 down 10A- Rear O2 sensor
O2 up 10A- Front O2 sensor
Fuel pump 10A -Fuel pump unit
Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor.
A/Con 10A - A/C compressor controls, cooling fan
BTN 30A- Brake light , high mounted stop light.
Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination
Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination
Head low 15A- Headlight
Head Hi 15A-Headlight
Horn 15A- Horn
Inside kick panel
G4 quicksilver 733/640. Does start up if left off all day. Stays on for 10 minutes then shuts down. After that, the time between the start up and the abrupt shut down gets smaller. All fans look to be working fine. I have tried everything except replacing the battery and the power supply. Other than replacing the power supply at added cost, how could i repair it myself before handing over £150?
I have a G4 with this same problem. One day the computer went into sleep mode and never woke up. Now when I try to power it on there is just a short kick of the fan but it does not turn on. I purchased a used power supply on ebay and replaced it but I still have the same problem.
