Does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Kenmore model series 55471 ice maker wont make ice but only been plugged in for couple of hours. ALso frig side doesnt seem to be cooling right, but again only plugged in for about 2-3 hours. Was told worked fine in Feb., 6 months ago, was not running when we got it
The new plastic fan and remove the bronze metal clip on the shaft of the fan. Gently push the fan into the fan shaft. Approximately 1 shaft should protrude forward of the center. Use needle nose pliers to spread the metal clip in his hand and slip it into the hub.
<a rel='nofollow' href="http://www.farango.com/">r4 nintendo ds</a>
