It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Keep your finger on the ipod/aux button for several seconds and the input switches from ipod to aux. Hope this helps
I have a i-want it iw900 and i have lost the remote. is there anyway to select the aux function with out having to order a remote? is there a way to change the function via the buttons?
