20 Most Recent
Digix BT-100 Portable Bluetooth Wireless Speaker with Microphone BT-100 PURPLE Questions & Answers
Digix BT-100 Portable Bluetooth Wireless Speaker is not recognized by my android MOTO X cell phone.
Is the speaker paired with another device?
You may try turning off the bluetooth on your phone, turning off the speaker, turning back ON the speaker and then turning on the bluetooth on your phone again. This should reset the phone to SEARCH for BT-100.
Once you SEARCH for available devices you should see BT-100 on the list. Select BT-100 and it should pair. If it does not CONNECT be sure to press BT-100 again to connect. The speaker will BEEP, indicating that the speaker and the phone are now connected.
If you continue to have trouble feel free to contact the manufacturer at
[email protected] or going to http://www.contelusa.net
Bt-100 bluetooth speaker volume to low can't turn up
There are several issues that may be causing the volume to be very low.
SPEAKER VOLUME:
(1) When you press the Vol+ button on the speaker does it make a beep sound? (It should, even if it can not longer go up or lower).
(2) Be sure to continue pressing the Vol+ Button to ensure that the volume does increase.
(3) While this is rarely an issue, may want to check that the speaker is charged.
DEVICE VOLUME:
*Please note that some devices have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Ensure that Media Volume is on.
(2) Ensure that the volume is turned up on the device by using the devices Vol+ controls
MEDIA VOLUME:
*Please also note that the media being used (Youtube, Hulu, Music Player, etc.) may ALSO have a separate volume control aside from a blue tooth devices volume adjustment.
(1) Check that the volume within the media is turned up as well.
Hope this helps! You can also contact customer service for DIgix at 1-866-770-3688 for further assistance.
It pairs for a few seconds then quits
Has the speaker been paired with another device?
Is the device (phone, tablet, etc) paired with another bluetooth device that is within range?
If the answer is YES to either of the above questions this could be what is causing the problem. Please note that most devices (phones, tablets, etc.) can only connect to ONE bluetooth device at a time. Also note that the BT-100 speaker can only connect to ONE device at a time.
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
Is it waterproof
This device is Water RESISTANT. IPX-5. It can get wet, be splashed and fall into water. As long as it is quickly removed and too much water does not seep through the top holes the speaker will be fine. It works great in the shower where it will constantly get splashed or pool side.
Battery light indicates its not charging
Back to the shop. Or look in the manual. Next time you better place a problem like this in the category audio, or speakers. It accedentely? is between Digital camera's.
How do you get an LG LV720 video cassette recorder out of safe mode?
To get your LG LV720 video cassette recorder out of safe mode, you can follow these steps:
Locate the original remote control that came with your VCR.
Look for a button marked as C.LOCK or LOCK.
Press this button. This should allow you to exit the safe mode3.
If you don't have the original remote, you might face some difficulties. Some users have reported success by pressing the record button for 6 seconds on their Panasonic VCRs but it's unclear if this will work for an LG model.
Movavi video editor 11
which type of system you use ? if your computer is not equipped with the requirement, this will not work properly,
