YES BECUASE IS DEFECTED BRING THE PAPPER WORK MAKE SURE IS PACK'D JUST THE WAY YOU GOT IT.AND DO YOUR SELF A FAVOR DON'T BUY ANYTHING MADE OUT OF PLASTIC UNLESS IS A PLASTIC CUP. WHAT'S WRONG WITH A METAL MACHINE? IF YOU BUY A METAL MACHINE YOU CAN SET IT ON A TABLE.IF YOU WORRY ABOUT MOVING IT THAN YOU CAN BUY A SMALL TABLE WITH WHEELS..
I WILL GIVE YOU A PERFECT EXAMPLE,,,WHEN YOU DRIVE ANYWHERE AND YOU SEE A CAR ACCIDENT THE FIRST THING YOU'LL SEE IS PLASTIC ALL OVER THE STREET....OK!!
SOURCE: Janome 3022
Hi, ALL machines will require lubrication at some point.It will require covers to be removed however. Apart from the cover over the needle bar / presser foot area, I dont recommend you try taking them off as without knowledge of exactly how, you can break the retaining clips. Cleaning out the lint REGULARLY is very important - you can use a vacuum with a crevice tool. So, remove the 'lamp' cover and needle plate, vacuum out thoroughly. Apply a drop in total to the length of the needle bar, a small amount on the presser foot shaft.Remove the black plastic shuttle, clean around it, apply a SMIDGE of oill to the 'track' on the underside of it. Thats about all you will have access to. Use proper sewing machine oil - NOTHING ELSE! If you sew a lot, get it serviced proffessionally - they will do the areas you can't access. Good luck!
SOURCE: Top tread bird nesting.
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
SOURCE: looking for a instruction book for janome limited edition sewing machine my style 30
I've always been able to get a free PDF downloadable manual from
Janome. They are happy to send you a manual for your specific machine
via email, and they've always been very helpful to me. Here's a link
to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
