Hey guys I am trying to install my copy of Fifa 10 for pc on windows vista... I get all the way through the install almost until a message pops up telling me my group10.cab file is corrupt and it is needed to finish installation, help please
If you receive this message it means that the Shadermoddel that your
card has does not meet the min spec. To run FIFA 11 PC you will need at
least Shader Model 3.0 ( a newer video card )
1. Installation problem.. Try uninstalling the game and reinstall again..
2. Your game require a graphic card. make sure your pc is having one. and make sure your pc meet all the minimum requirements to play the fifa 08 game..
Here are the minimum system requirements for running FIFA 08:
Operating Systems: Windows XP SP2, Windows 2000 SP4 or Windows Vista (Windows 95, Windows 98, Windows ME and Windows NT 4.0 are not supported)
Processor: 1.3 GHz
RAM: 512 MB
Video Card: DirectX 9.0c Compatible 3D accelerated 64 MB video card or equivalent . Here’s the list of supported chipsets
Are you installing within Windows? If so reboot your system with the Windows 7 system disc inside your cd rom, you should see message that says Press Any Key To Boot From CD at this point press any key. The system will load the installation files the it will ask you if you want to install or perform recovery you will select install, then it will ask you if you want to format your hard drive. Formatting your hard drive will erase the entire drive so back up any desired files. This will successfully install windows 7.
YOUR CONFIGRATION IS ABSOLUTELY FINE THE PROBLEM IS WITH WINDOWS VISTA. FIFA 09 FREEZEZ IN VISTA EVEN IF U GET A 1GB GRAPHIC CARD. SO WHAT I DID WAS INSTALLED WINDOWS 7 AND TAKE MY WORDS THIS GAME RAN ON FULL RESOLUTION EVEN WITH MY 128MB GRAPHIC CARD. SO IF U R REALLY KEEN ON PLAYING THIS GAME SWITCH TO WINDOWS 7
is the driver you are trying to install supports vista? check whether if its also for vista and or try visiting their website and look for driver downloads compatible for your mouse and your OS.
