You using and play Computer games with huge data and need power full computer with advanced features.
This is normally happen on standard Computer to play 'advance games' like FIFA (as you have), F1, Motogp, SBK etc.
My suggestion is just play the game with your disk or upgrade your Computer with better one (RAM, video / vga card, and processor).
If your game did not come with a serial, contact EA for support.
If it did and does not work, 1) Verify that you are typing it in correctly. Remember that O and 0 are not the same key! 2) Try installing using a different optical drive. Sometimes the drive cannot read the disk to verify the serial. 3) If rundll32 is running in the background, this may cause issues when attempting to enter the serial.
If all else fails, contact EA for support.
Click here for EA's serial replacement instructions.
In that case please check that you have installed the game correctly or the serial number that you provide is correct.If the problem still continue then check by putting the CD into the CD ROME and then play.If it still continue that means that CD is gone.But you can play that game by craking the CD.For that you should download a craker from the internet.
first you have to go crack folder of that game disc, after open that
crack folder you have to copy that game.exe file, and then you have to go
the game directory where you have installed that game, there you have to
paste that, they will ask you to replace, then you click on "yes"
button. now you can play that game easily....
thank you
First make sure the correct cd is in the drive alot of times these sports games come with 2 disks.
Secondly if you are still having problems go to this link and download the software as its on the website it will let you play the game with no cd so you should not have a problem anymore
http://m0001.gamecopyworld.com/games/pc_fifa_2008.shtml#FIFA 08 Patch #2 [MULTI3] No-DVD/Fixed EXE 2
it reads in the user manual the back of it, or in the case of the product. if you have lost the code, theres not much you can do,, buy the game again and don't loose the code.
