20 Most Recent Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Questions & Answers
1. delete the following registry keys.goto start run - type regedit and press enter.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Winsock
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Winsock2
2. Reboot your computer.check if it works.
3. Go to start - control panel - the network connections folder, right click the icon for your local area connection
select properties.
4. single click on internet protocaol(TCP/IP) Click install, choose "protocol", and click "add..."
5. Click "Have Disk...", enter "\windows\inf", click OK
6. Select "Internet Protocol (TCP/IP), click OK
7. When the process is complete, reboot your computer.
Microsoft... | Answered on Sep 09, 2019
Even though you say you did not mess with the settings, I'd suggest you check the audio recoding settings in Vista anyway. Better make sure all those are correct.
If you are using an internal microphone, I'd suggest trying an external one (if you already have that, try a different one). Even a webcam with built in mic will do. That way you can isolate the cause.
Based on my experience I'd say that chances are bugger that it is a loose contact, so make sure to check your plug if it's an external mic.
Jules
Microsoft... | Answered on Apr 04, 2019
Download Revo Uninstaller and use that as a program removal tool. It gets rid of the program totally. I mean totally wiped out even on registry. Download it's Free Trial here http://www.revouninstaller.com/revo_uninstaller_free_download.html.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button and leave a short comment to let other people know how I help you. Have a good one!
Microsoft... | Answered on Dec 02, 2017
Contact the publisher for a legal key.
Software CounterfeitingThis type of piracy is the illegal duplication and sale of copyrighted material with the intent to directly imitate the copyrighted product. In the case of packaged software, counterfeit versions often include copies of CDs or diskettes containing the software programs, as well as related packaging, manuals, license agreements, labels, registration cards, and security features.
Software Piracy is stealing. If you or your company were caught pirating software, you could be held liable under both civil and criminal law. If a copyright owner brings a civil action against you, the penalties in the U.S. may be up to $150,000 for each program copied. The U.S. government can also criminally prosecute you. If you are convicted, you can be fined up to $250,000, sentenced to jail for up to five years, or both.
If you have the original Installatin Disc, you can call microsoft at 1(888)571-2048.
One of the techs can give you back the lost Product Key.
Are you installing within Windows? If so reboot your system with the Windows 7 system disc inside your cd rom, you should see message that says Press Any Key To Boot From CD at this point press any key. The system will load the installation files the it will ask you if you want to install or perform recovery you will select install, then it will ask you if you want to format your hard drive. Formatting your hard drive will erase the entire drive so back up any desired files. This will successfully install windows 7.
i try to give you the solution bat i cant because the windows words there in?when i press post solution fixya is tell me to Please use English characters only, so you can email my and i can send you the solution via email.. marocco11@mail.com... cheers..
Microsoft... | Answered on Nov 04, 2013
If you are doing a full reinstall of your vista system using a genuine disc then you should be able to choose English during the reinstall.I hope this helps .
Andrew
Microsoft... | Answered on Mar 28, 2011
According to the Microsoft Tech center, the "root cause patch is stopping the start of Vista" is a problem whereby a Microsoft auto patch did not install correctly and has corrupted your boot sequence. They say it can be fixed by the repair, but many people have complained that the repair made no difference, like you found. The best advice I can give you is to take out that hard drive, put it into another PC, back up your stuff, format and reinstall Windows. That's currently the easiest way.
Microsoft... | Answered on Mar 19, 2011
did u delete your trash can contents
Microsoft... | Answered on Mar 13, 2011
I recommend 1 per hard drive.
If you have 1 hard drive, then just one.
If you have 3, then 3.
Simply put, you can install windows into a hard drive already running windows.
Microsoft... | Answered on Jan 25, 2011
Install the Audio drivers compactible with windows Vista home basic by going to the manufacturers website.
Go to device manager and check if the driver is installed if they are then uninstall them and then reinstall them by downloading the latest drvier from the computer manufacturers website
Microsoft... | Answered on Dec 19, 2010
Boot to the Advanced Boot Menu by tapping F8 several times at boot to get to the advanced boot menu.
Choose Last know good configuration or.....
Repair Your Computer'
Choose language and click Next
Choose your User name (by default it will say administrator) and type in the password to login
Click on 'System Restore' and take the system back to a previous date.
Or go through this > 'How to use System Restore to log on to Windows Vista when you lose access to an account'
http://support.microsoft.com/kb/940765
Hopefully this fixes it. If this doesn't fix, you may have to do a reinstall meaning that you will loose your data.
Good luck and if there is anything else please post back.
Microsoft... | Answered on Dec 14, 2010
> I think that I will need a new laptop.
No!
All you need to do is to "backup" your files (E-mail, contacts, music, picture) to some external device, e.g., USB memory-stick or CD/DVD-writer.
Then, reinstall Windows, using the original set of "System Restore" CD/DVD disks,
install an anti-virus, run Windows Update several files, and reload your files.
Or, any computer-store will do the above, and charge you $50 to $100.
Definitely *NOT* (yet) the time to purchase a new computer!
Microsoft... | Answered on Dec 06, 2010
You must feed the SATA driver to the XP installation program.
Options include.. disabling "Native SATA Support" (or enabling IDE emulation) in the BIOS which allows you to install and run XP without the SATA drivers..
or
Using a USB floppy drive to install the CORRECT SATA drivers during the XP install.
or
Finding and slipstreaming the CORRECT SATA drivers for your specific laptop.. The correct XP driver information for computer can be gleaned by writing down the appropriate Vista Device Manager listings BEFORE formatting the computer.
Microsoft... | Answered on Nov 13, 2010
Just do the following Press Windows key button and simultaneously press D button
Now Press and hold Control button and now keep scrolling the mouse scroll wheel (dont move the mouse just scroll the scroll wheel) up and down side, you can see the sceen getting smaller or bigger, Leave the control key as per your preference of screen size.
ENjoy.
Microsoft... | Answered on Oct 01, 2010
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
Popular Tags
145 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
vista will not even open tried safe mode
  • Computers & Internet
