The Nikon D40 in Auto Focus mode will only allow the shutter to operate when the image is in focus. When looking through the viewfinder, the bottom edge provides information relative to what you are looking at. See the image below:
Item 2 is the focus indicator. It must be illuminated to allow the shutter to release. If it is not illuminated, the lens has not been able to determine the correct focus. This can happen when attempting to take a picture in low light conditions. Make sure that the front facing "focus assist lamp" on the camera (between the shutter release and lens) has not been blocked or disabled (Settings Menu # 09) and try again. Many times, you will see and or hear the lens "hunt" for proper focus - the lens will travel from one end of its focus range to the other trying to find focus. When it can't, it stops and prevents the shutter from releasing. You can get around this "unable to focus" issue by changing the position of the switch on the lens to "Manual Focus" mode, detailed below:
If a lens has an "A - M" switch, move it to "M" to manually focus. If the switch
says "M/A
- M " then leave on M/A (unless you're going to be taking several or more in manual mode), as these lenses may be focused manually at any time in either position. As soon as you tap
the shutter button in M/A you return to autofocus.
More advanced lenses, like the 18-200mm, 70-300mm VR and 18-135mm,
and any lens with an M/A position, may be focused manually at any time
without moving any switches. Leave them in their A or A/M positions.
I hope this helps and good luck!
Is the battery charged? Try a different battery if you have one, otherwise recharge the one you have. Does that make any difference?
