Home Logo
Posted on Aug 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Soft close toilet seat is loose on kohler toilet. how to tighten it up?
Anonymous
Level 3:
  • Master 707 Answers
  • Posted on Aug 12, 2010
Anonymous
Master
Level 3:
Answers
707
Questions
0
Helped
182861
Points
2158
There are two plastic tabs that clip up on the back of the seat and tighten not at bottom.Hope this helps.
1helpful
I have a Koehler model 703 84679aa. The seat bolt is loose and you cannot get to the but without pulling the toilet. Does anyone know how to tighten the seat without removing the whole toilet?
Kohler Rialto / San Raphael toilet problems # 84499 ...
? 13:04
www.youtube.com/watch?v=Hmhb4H4HYMY
Mar 31, 2012 - Uploaded by Dino Pinch best kohler rialto / san raphael toilet repair video on youtube. ...the kohler brand rialto model wisks away the offending lumps of ur behind product, never to be seen again. .... 'can't screw a lightbulb in'. .... How to Install Toilet Seat on Kohler One-piece ModelK3434 - Duration: 7:10. by emf4kv 20,891 views.
Jul 26, 2015 • Home
How do I tighten a wobbly soft close toilet seat?
There are two(2) nuts under the outside edge of rim of bowl(bottom section)right in front of tank. use fingers to tighten, and pliers to secure. If it will not tighten, then the posts molded in are loose, requiring replacement. Sometimes even if new on these types.
Aug 27, 2014 • Home
Why does my kohler quiet seat not soft close anymore
The cams are worn out inside of seat or it may be to lose you have to tighten up the seat if there is any adjustments if not it is worn out replace toilet seat.
How to tighten the seat
Tighten the seat by holding nuts on the underside of the bowl and taken a screwdriver and put it in the slots on top of seat under the caps that just pop off.
1helpful
2answers
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
A plastic clip that holds the seat to the toilet broke. Is there a repair?
You need to check with Kohler 1-800-4-KOHLER they might offer it they keep changing service parts on us
17helpful
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
