Home Logo
Posted on Sep 06, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Wickes 800 S/F Quadrant - Central opening shower cubicle - Item number 160576. This was bought in June 2008 and the part that fits into the runners at the top of the door to allow opening/shuting has broken. The door fell off at the top runner due to the part that holds the screw in place has worn away (as it is only plastic!). Can you buy this part separately?
Bill Boyd
Level 3:
Top Expert:
  • Home Master 53,816 Answers
  • Posted on Sep 06, 2017
Bill Boyd
Home Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951359
Points
172802
Contact the manufacturer direct yourself and ask them for the part
1 Related Answer
uspartscente
US Parts Center
  • 719 Answers
  • Posted on Sep 01, 2011
SOURCE: Bottom door runners are broken
The best place to find shower door parts is at your local Glass Company. if that fails then CR Laurence.com has all the parts too.
US Parts Center
2answers
Bought the Tao shower base and now can't install it because no one has the drain assembly for it. Where can I get the drain assembly
I bought the rubber donut when I bought my shower. It slides down over the 2 inch PVC drain pipe and seals against the drain hub
The Swan Corporation •515 Olive Street, Suite 1800 St. Louis, MO 63101 p (800)325-7008 •.St Louis, MO 63101 p (800)325-7008
Talk to the about the drain it comes with their shower base. Also go to plumbing sup[ply and talk to them
Also go to hHD and look at
Sioux Chief 2 in PVC Shower Drain with Strainer 828 2PK The Home Depot
Mar 14, 2018 • Plumbing
1helpful
Shower problems I have a zy-137 shower and steam cubicle The steam wasn't commingled through the valve and I turned it to have a look one it has come unscrewed and there is a visible hole and I am unable...
Somehow you have to get that pipe coming back through the wall of the shower.
There is a pipe with threads on it that the nozzle threads onto.
Once you can get that pipe back through the shower wall you can thread the steam nozzle back on.
If the steam nozzle has been replaced onto the threaded pipe you can trouble shoot your steamer as to why there is no steam coming out.
ROD
U S Parts Center
May 14, 2014 • Home
Water is flowing back to shower tray macerator not switching on
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
15helpful
6answers
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
1helpful
I have a triton Amber 3 shower. No water flows when switched on - but the mains LED is lit and water is available
the solenoid has failed,thus not opening up to allow water flow,i have found that spares are fairly expensive for tritan. if you find out the rating ie 7.5 kw etc then buy a replacement shower from wickes their showers are tritan and are normally like for like fitting,also a lot cheaper than showers that have tritan marked on them.
Sep 05, 2011 • Home
1helpful
Fitting of plastic seals to bottom of shower doors Bath Store Plan Quadrant 800. These are easy enough to fit as they just slide on but when in place we cannot shut the doors!!! Do we have to trim the...
You generally put the seal in and cut it flush with the edges of the doors and then using pliers or vise grips squeeze the end of channel on to seal to hold it in place. Thank you
Jun 11, 2011 • Home
Aqua steam shower cubicle not doing as it should when pushing control buttons example press radio button shower comes on etc
If you had it installed by some one have them come back and rewire it correctly and if you did it get out the wiring diagram and check your wiring.
Feb 10, 2011 • Plumbing
I've got an old wickes garage door opener, we've just moved in and no remote supplied. I want to wire a push button open/close inside the garage to test and make sure the motor system works before I buy a...
You can also get remote units that connect to the same terminals that you would hard wire a button to. You really do want a later remote, as they all now use rolling code technology. Essentially you have to "invite" a remote and the unit and remote agree on a code. From that time on, the code changes every time that you use the remote (automatically, you do nothing). Way better security, and a guy cannot just run a frequency generator and open your door.
Sep 17, 2010 • Garden
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
