The governor shouldn't need to be adjusted unless it has been bumped or removed. But, if your sure the problem is the governor, you adjust by moving the governor arm in the direction that opens the throttle valve all the way open. Remove air cleaner and filter to inspect while doing this to make sure. Then note that direction, keep in this position, then loosen small nut on governor linkage at base of unit. With a needle nose pliers, turn small center shaft of governor linkage(the part that leads inside engine) in same direction you moved the linkage in earlier step. While holding in place tighten small jam nut. This is called a static set, which is a factory standard. Also, make sure throttle cable is in wide open position when doing this. Good luck.
I’m happy to assist further over the phone at
https://www.6ya.com/expert/layne_0fccff498c319c32
