20 Most Recent Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp Questions & Answers
3answers
Briggs & Stratton 20hp Intek engine over-revving continuously.
Do you have governor adjusted properly? Possibly "PidStu" question, but you'd be surprised how many I've seen. Can you move the governor linkage arm with your fingers or does it seem to be locked in position? If it is locked, it is adjusted improperly. fixya1-brgpylccbkzzzzcjghmgmbii-d-0.jpg
6/1/2022 10:53:14 AM • Briggs &... • Answered on Jun 01, 2022
Belt routing illustrations
try PartsTreeRepairClinic
2/8/2018 12:02:43 AM • Briggs &... • Answered on Feb 08, 2018
Where are all vacuum lines
What are you working on? Details please.
7/30/2016 3:06:43 AM • Briggs &... • Answered on Jul 30, 2016
How do i replace the bladeees belt?
Remove the deck, Find the pattern of the belt direction on each pulley. While deck is removed check for sharpening blades and greasing spindles.
5/13/2016 7:26:09 PM • Briggs &... • Answered on May 13, 2016
Can you replace the fuel primer rubber part? If so, part # and instructions?
Go to a small engine shop and they will have what you need If possible take the old one on and even if its pulled apart they can give you a new one. Give them the make and horse power. There is a little steel some are plastic ring you have to take out to get the bulb out. I got mine with a small screwdriver. In putting the new one in make sure the area is clean and shove the new bulb in and put the ring over top and use a socket that will just slip in and tap it in as far as it will go.
3/17/2015 12:50:52 AM • Briggs &... • Answered on Mar 17, 2015
S2046 low battery tried to start. Replaced battery now no sound, no start. Yes did hook up correct cables. Where can I find images of safety switches?
When trying to start with a low battery the engine Sometimes will stop on the top of the firing stroke putting it under extreme compression..almost like being stuck..you must turn tne engine backward a little just enough to get it off the compresdion stroke then try and start..This very same no click no nothing even when jump start happened to my cub cadet this summer after trying to start with a low battery...i used a pipe wrench and turned the dry shaft back and it started..then and all summer...give it a try good luck..
12/2/2014 9:29:10 PM • Briggs &... • Answered on Dec 02, 2014
What weight oil is used in a Scott's s2046 Riding Lawn Mower
30 weight oil not 10w30 just 30 weight
7/14/2014 3:52:18 PM • Briggs &... • Answered on Jul 14, 2014
Why does my B&S engine runs wide open even with throttle off 20 HP
Check the cable connection down near the engine, it should be attached to the throttle lever, it is not uncommon for the screws that clamp the cable to come loose
7/5/2014 8:42:17 AM • Briggs &... • Answered on Jul 05, 2014
Scott's 2046 ignition switch broken. How do I
There should be a rubber slotted cover that key goes through. This should pop off with a screw driver to expose hex nut. Unscrew hex nut and replace switch. I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
10/19/2013 9:48:46 PM • Briggs &... • Answered on Oct 19, 2013
Why is my 20hp B n G Keep flooding?
check that the float valve is closing fully may have dirt under seat.
1/17/2013 12:42:34 AM • Briggs &... • Answered on Jan 17, 2013
Engine idoling way to high
An engine will idle too high because of : improper govenor setting, improper carb setting, intake leak, or missing carb throttle plate.
10/25/2012 5:52:45 AM • Briggs &... • Answered on Oct 25, 2012
The plastic starter gear keeps
The lawn mower you have is manufactured by the John Deere Company. They handle all inquiries and complaints on these lawn mowers. You can contact them at 800-537-8233
Hilary @ Scotts
5/16/2011 8:14:14 PM • Briggs &... • Answered on May 16, 2011
I have a scotts/john deere
I would try and fill the case with 50 weight oil It might be low. The hose should come to the right side of the pully door on the middle of the tractor between your legs.
Terry
1/10/2011 7:57:48 AM • Briggs &... • Answered on Jan 10, 2011
The mower deck belt on my scotts s2046 comes off
you should have some type of belt tensioner,most common type is a pulley with a spring to hold pressure on belt.Spring may be missing or stretched {2}belt could be stretched {3}pulleys may be out of alignment
10/6/2010 5:47:42 AM • Briggs &... • Answered on Oct 06, 2010
Briggs & stratton 17.5 hp has fuel, spark and good air filter no start.
Likely either the engine is flooded or low compression.
A simple go no go compression test is remove spark plug and press a thumb or finger firmly over the plug hole and crank engine. It should forcibly push your finger and make a loud PFFfft sound. No or little sound equals insufficient compression.
If the push rod was not bent, there was no reason to replace. If it was bent then I question how you set proper valve lash with new pushrod as the typical cause for a bent rod is a displaced valve guide.
If compression is OK then likely it's simply flooding and you have a carb float/inlet needle issue. Crank engine, remove plug and if it's saturated with fuel then it's flooded and a flooded engine will not fire, even with starter fluid.
Comment for further assistance.
11/6/2023 1:03:20 AM • Briggs &... • Answered on Nov 06, 2023
Briggs & Stratton Starter Scott's Equip S2046 Briggs Stratton 20hp Logo
25 questions posted
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Garden
Most Popular Question
engine idoling way high
  • Garden
