Polycom VoiceStation  300 (220017910001) Wireless Audio Conference Logo
Posted on Aug 05, 2010
I set up the polycom as instructed... I even confirmed with my helpdesk that the line is analog. When i turn the unit on I get a high pitched buzzing sort of sound... no dial tone? I also cannot dial in from another line. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Aug 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
6360
Points
13
Try to plug a cheap analog phone into the same line instead of the voicestation to verify that it is indeed analog. It sounds as if you connected the phone to a specialty PBX line or similar. There are analog PBX that only work with their own phones. You can also try to connect the phone at home and see if it works on your analog line at home.
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
When I talk, my friends complain of a high pitched buzzing. I'm using the Turtle Beach X11 via a wired controller on the Xbox 360.
Same issue here. Can hear the high pitch buzz, and friends complain about it.
I have 2 Turtle Beach X11 headsets, and 3 Xboxes (std, Elite, slim)
Unplug the mic, and no high pitch buzz. Plug it back in, and its back.
Tried all 3 boxes experience same issues
Playing with volume and mic settings doesn't make a difference.
Would love to have a fix for this :-)
3helpful
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
2answers
Polycom Sound station - help it won't work!
what line have you connected to the polycom? you will need to connect a single line circuit line.
2answers
High pitch buzzing.
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Regards
Rifaa
When tv is on it makes a loud buzzing noise
What is the make an and model of the set?
Is the buzzing from the speakers or from inside of the set?
Is it a high pitched frequency buzz or a low pitched frequency buzz?
There are many things that can cause a buzz in a TV set. In anycase, the set will require tech service.
Jerry G.
1helpful
2answers
Polycom 2201-03309-001
The older Polycom SoundStations have power supplies that allow either anaog or digital signals. The phones themselves will work on either.
If your office phone systems are different, or if the extension it was originally plugged into was configured for analog and you are now plugging into digital would explain the problem.
Paul
Edge Telecom
[email protected]
High Pitch buzz noise when plugged in and it doesn't turn on
The tv has a shorted component and that is why is making the noise,call a qualified technician to find it and dont try to use it anymore.Is not a fuse.
Top Polycom Lands Phones Experts
k24674
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
