20 Most Recent
Voyetra Turtle Beach Turtle Beach Ear Force X1 Headphones Questions & Answers
My turtle beach X11 has
To test the headset, connect it to your PC and listen to some music. Use the green plug and USB. If both speakers work and it sounds fine, then there's nothing wrong with the headset.
Why don't you contact Turtle Beach directly for help?
My turtle beach x 11
hey my headset has the same problem!
I Opened the white chat thing and wires were off what they were suppose to be on so my grandfater is going to soter the on. Check if that is your problem
When i talk people cant hear me though turtle
If you have an X1 headset...
Try using the X1 headset and mic with your PC (sound card). Green plug goes to green jack, Pink plug goes to pink jack. Can you hear your voice thru the X1 mic on your PC? If yes, then the mic works but the chat-controller cable is probably broken and should be replaced. If no, then the mic may be broken and you should contact Turtle Beach's tech support for help --
[email protected].
My turtle beach only plays sound from one ear, its
Plug in the green and USB jacks to your PC and listen to some music. If both speakers work, then there's nothing wrong with the headset. Contact TB directly if you need help finding out what's wrong with your setup.
Dog chewed through Turtle Beach X1 wire any advice on fixing??
Your best long term fix will be to solder the wires together then tape them individually and finally tape the whole thing. Second choice will be to use crimp (**** splice) connections and then tape. Last choice will be just twisting stripped wires together and tape everything.
I can't hear people talk,
Check your mic settings
Had a similar issues where I couldn't always hear xbox live chat conversation. Sometimes it would work, other times it wouldn't.. not 100% sure why though.
Tried different xbox, different controller and different Turtle beach head sets with similar issues
Setting the mic output to speakers allowed me to hear what people were saying at the expence of not being able to easily control the chat volume with the analog volume control on the chat head set cable.
Hope this helps
