I keep getting a dc error during the spin cycle unless the machine is filled.
Rich
This error code is displayed when the machine was unable to spin the basket, and is associated with the 'dc' user code. Either code can be displayed indicating the machine was unable to spin, and they both point to the same two components as a possible failure.
Viking Range Repair
Also ck the Pump I was told dc means (Drain Cloged) mine had dc and would not spin or drain so I sucked the tank & Basket out with a wet dry vac and now it goes thru all cycle and don't stop now.
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
I keep getting a dc error on my top load neptune tl washing machine.
I'm getting a dc error on my Neptune TL. Also, the spin cycle doesn't complete. It spins for a few seconds then stops and it repeats this over and over again but it never actually completes the spin cycle.
