Samsung SGH-D900 Cellular Phone Logo
Posted on Apr 26, 2008
Charging my battery on my d900i doesnt charge i bought a new battery and it still doesnt charge has any one an idea what it could be
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Apr 26, 2008
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
5660
Points
42
Try new charger. Else send it back to manufactures if it's still under warranty.
1helpful
Samssung D900i not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Batterry plluged in not charging
Buy a new AC chager the cables wear out .I have now bought 3 in 4 years.Ebay about 6 pounds.
2answers
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
DCR-HC42 doesnt work with batteries
I recommend you taking this into the nearest BatteriesPlus...they can test your batteries to make sure they are good. They can also help figure out the problem. www.batteriesplus.com
1helpful
3answers
Charging
i think the solution to this problem is to let your cellphone go dead
my friend told me today that my d900i was overcharged so thats why it wouldnt charge throught the power outlet
let the battery cell die and than charge it
see if this helps ( i have to try it too , just waiting for my cell to go dead lol)
Phone not charge.
right this happened to me too
its the charging port the pins in it are crushed and when you put in a charger it just pushes them of the plastic so they cant charge
basicly it the charging port
1helpful
2answers
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Recharging doesnt work
OK Try to replace a new one battery then observe if can charge!? if not charging u have defective charging pin! or charging IC.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
