Black & Decker Black  Decker Cordless 24 Volt Lawn Mower  Cmm1200 Logo
Posted on Sep 24, 2017
My 24 volt lawn mower is all of a sudden not working, it is just over 2 years old. You can hear it but the noise it was giving off is missing?? It doesn not have the same sound. The blade is turning, I am wondering if it is the sound of a fan that I am not hearing?? What can I do, i need to cut my lawn but cannot use my lawnmower. thank you, Elizabeth
rightangular
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 07, 2017
rightangular
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
3232
Points
10
If the blade is turning it should cut grass. Try mowing. If it's not cutting the grass then the blade is not turning, or is no longer turning at the proper speed. Look for a fuse or circuit breaker.But after 2 years the battery may have a problem. Try the manufacturers website for help: http://www.blackanddecker.com/en-us/support
5 Related Answers
Anonymous
  • 2992 Answers
  • Posted on Apr 17, 2009
SOURCE: changing batteries in black and decker cordless lawnmower
You can find parts information and exploded views for your mower here. You'll need to pick the series mower you have from the list. The service site's home page is here. At the bottom of the center pane is box where you can enter your model number to find the manual. With the views they give, you should be able to get the mower apart to replace the batteries yourself. Good luck on the project!
Anonymous
  • 1605 Answers
  • Posted on May 22, 2009
SOURCE: electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
Anonymous
  • 1865 Answers
  • Posted on Jul 29, 2009
SOURCE: my 24 volt 1200 watt cordless mower abruptly
You'll need a DC voltmeter and have to start checking the circuit from the battery to the motor
Anonymous
  • 11896 Answers
  • Posted on Sep 04, 2009
SOURCE: I have an old Black and Decker 18 electric mower
Here is the black and decker website:
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1498.1670
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
sandham
  • 52 Answers
  • Posted on Apr 15, 2010
SOURCE: Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
My riding lawn mower will not start. Only 2 years old.
if you can give some information as to what it is or is not doing i may be able to help you. if it is only 2 years old i would guess it is a dead battery.
Nov 11, 2017 • Garden
2answers
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
Can you reprogram a 24 volt(2-12s) on homelite lawnmower?
no once there memory is gone thats it and i no there are expensiveyou memery train them when you first charg them by making sure you completly discharge the battery once there trained they last a lot longer
May 14, 2013 • Garden
Task force lawn mower 24 volt battery
Battery Source - if it's made they can get it but usually they use 2 - 12V batteries and wire them in series to get 24V
Mar 23, 2013 • Garden
Was runnibg tractor, it suddenly cut off would not crank, put more gas in still no crank,, when turn key made a clicking noise , then a type of humming noise ,, battery is about two yrs old, got at...
Try jumping the battery with a car as long as the two are 12 volts.
If this starts the mower, it is the battery.
If the mower won't start with a jump, there is a different problem.
2answers
Tractor wont start unless I jump it
How old is the battery? When you get it started put a digital volt meter across the battery terminals and with the throttle about 1/2 open check the voltage. If should be over 13 volts DC if your charging system is working ok. If it is over 13 volts your battery has probably just given up. Lawn mower batteries are only good for 2-3 years. A trickle charger can extend the life if used.
I hope this helps.
2helpful
About 3 months ago whilst mowing lawn, the engine stopped.
Likely that the piston rod is snapped. I had a mower engine break down this way. To test it, slowly pull the starter cord and listen for any sounds. If you hear clunking, it is likely that the piston rod is broken (i.e. the engine is broken for good). If you don't hear any clunking, but hear the usual slow thwup thwup thwup of compression as the cylinder moves (sound will come primarily from the muffler, you may have a blown gasket in the engine, which is fixable, but only if you are mechanically inclined. Good luck-
Apr 04, 2009 • Garden
Rechargeable lawn mower lacks power even with replacement battery. Six or seven year old rechargeable Black and Decker 24 volt mower. Replaced the battery last year after it became unable to mow my...
just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
