20 Most Recent Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Questions & Answers
2answers
I accidently cut the extension cord with my
fuse probably went in the plug/extension-replace plug and mend the cable or replaceit
9/25/2018 4:38:25 AM • Black & Decker... • Answered on Sep 25, 2018
My Black & Decker trimmer starts and stops whenever I move the trimmer in any direction -- any advise as to how to solve this problem?
I'm not familiar with your machine, BUT... that description of symptom sounds suspiciously like a bad/poor electrical connection. The problem could be in many places:
  • plug
  • cord
  • switch
  • brushes
  • internal electrical wiring
The "solution" to this problem is for someone who knows what s/he is doing, to troubleshoot the defective machine, determine the defect, and properly repair or replace the defective part.
9/12/2014 8:54:06 AM • Black & Decker... • Answered on Sep 12, 2014
0answers
2answers
My Black and Decker hedge trimmer's blades won't
Your blades are stuck together.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
6/22/2014 7:36:23 PM • Black & Decker... • Answered on Jun 22, 2014
1984 B&D double sided hedge trimer stops and
The only thing that i can think of is that somwhere along the length of the cable it has either atiny nick or it has been pulled so that when you hold it in a certain way it works . It is most likly near the tool end rather than the plug end.Only way to find it if it is is trial and error turn machien on and bend cable till it cuts out
12/3/2010 2:10:51 PM • Black & Decker... • Answered on Dec 03, 2010
I have a Hedge Clippers HT2000 and I need a Free
Go to this Free Black and Decker website to obtain your manual.
http://www.blackanddecker.com/CustomerCenter/Manuals.aspx
11/13/2010 12:04:15 PM • Black & Decker... • Answered on Nov 13, 2010
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
7/26/2010 7:26:02 PM • Black & Decker... • Answered on Jul 26, 2010
My hedge trimmer blades do not move when I turn it
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
7/14/2010 5:04:11 AM • Black & Decker... • Answered on Jul 14, 2010
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
37 questions posted
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Garden
Most Popular Question
cutting blade 8124 04 type 5
  • Garden
