SanDisk Sansa Fuze MP3 Player Logo
Posted on Aug 01, 2010
Can't load music onto my SanDisk Sanza Fuze Mp3 player
Can't load music onto my SanDisk Sanza Fuze Mp3 player from my itunes library. Any tips?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
516
Points
Itunes is what is known as proprietary software.
Which basically means that it only works with hardware of the same brand. (Apple- Ipod)
You will not be able Itunes to load mp3 files on a Sansa MP3 player.
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
2helpful
ScanDisk Sanza Fuze Manual and Info
You can download the manual from the manufacturer's web site at http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Can't download music frmo Window Media player or
what version on windows media do you have get number 10
1helpful
How I can put new music into my Sandisk Sansa Fuse 2 G
thats easy. you plug the device into the computer and open itunes, windows media, ect. and look in the side bar for you device. it should say something along the lines of Sansa fuze 2gb.  (windows media) go to the sync tab and select library there should be a side bar labeled the devices name on the right side. drag music from the library by clicking and holding the selected items and moving it into the sidebar. when you are done with selecting  music simply click the sync  button at the bottom of the sync sidebar.  (itunes) open a new itunes window and drag items from your library to you device and click sync.
1helpful
2answers
2answers
How do i get the videos i downloaded from lime wire onto my sansa fuze
use the software disk u got with your fuze to convert it so it works on your fuze
There is no sound
falty unit or the music on it caused the problem
When I p;ug in my daughetrs Sanza Fuze, my comp doesn't recoginiz
check to make sure you meet the requirements. You need Windows Xp with service pack 2 and windows media player 10 or above.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
