I have reliance broadband connection. They have provided ADSL modem. Now I have bought DLink wifi router.
I am not able to configure the router with that modem. Pls let help me on configuring this.
Reliance Wimax will be Dynamic (DHCP)
Step 1 :
Connect the Wimax wire from the wall outlet (power adapter provided by Reliance) to the computer directly. The computer must be in DHCP mode.
Check the IP Address of the Computer. It should be a public IP Address.
Step 2 :
Open a web browser. If you try to open any page, it will take you directly to the Reliance Broadnet Login page. Login with your Reliance User ID and Password. Then Log out.
Close the web browser.
Step 3 :
Now, connect the wimax wire to the WAN Port on the Router and the computer to any LAN port. You can open the Router Setup Page. Do MAC Cloning. Then, save changes. Run DHCP on the Router.
Also you can configure wireless network, by changing the SSID and security.
Step 4 :
On the wired computer, open web browser, go to Reliance Broadnet login page and login and start enjoying the service.
One problem, you might face is when the Router is turned off in between. You may have to repeat the Steps 1,2 & 3 to get the connection back.
How to configure Wi-Fi Router to Reliance Broadband connection. where i can use as desktop and mobile too
Thanks & Regards
LK
Quick questions
1. how did you setup your modem?..is it via PPPoA or PPPoE
2. can you please provide the model number of your modem
thanks
I am using Belkin G router,i hope same needs to help to configure on other routers too,
Step: 1
Under WAN settings:
Enable Dynamic and Hostname :http://www.reliancebroadband.co.in
(If above settings not works clone computer MAC address and assing to WAN port)
You have to wait for 3min to max.then it will works.
Step 2:
By default DHCP enabled and IP will assigned to your computer and all connected devices.
Step:3
First time you have to login with reliance website it may computer or laptop or any other device
Enjoyyyyyyyyyyyyyy
i am not able to access the net in my laptop but is working in the desktop
i HAVE RELIANCE BROADBAND AND I AM TRYING TO CONFIGURE THE LINKSYS WIRELESS-G ROUTER TO IT, BUT I AM NOT ABLE TO CONNECT
I have Wi-Fi Router, how to configure to desktop system which is connected with Reliance Broadband.
I have a different model linksys router and reliance broadband connection. I am not able to configure this wireless router. The same works with a netgear router. I tried all possible options and really fedup. Please help me out if anyone there is successful
I have reliance wifi max connection and I bought netgear wireless-g wgr614 router. I am unable to configure that. .. Can any body knows the procedure for configuration. Please please let me know...
Waiting for answersss..
regards
Harry
Hi, I have reliance broadband connection. They have provided ADSL modem. Now I have bought DLink router. I am not able to configure the router with that modem. Pls let help me on configuring this.
Describe 'not able to configure'.
Also, what model modem and WiFi router are you using?
