The ink absorber is a set of cotton and paper fibre pads in the very bottom of the machine. You would need to disassemble the machine to get them out and clean or replace them. Reassemble the machine and then find the printer service software to reset the waste ink and purge counters. Or buy another machine.
Try to remove the absorber (wear rubber gloves--very messy) and wash it in hot water and detergent. You can buy the replacement part if you don't want to try to wash it.
Call Canon at 732-521-7230 and they will sell you a new ink absorber pad.
You will need the reset code for your model printer. Find this by searching for canon used ink tank. One of the results should match your machine.
You can also take out the pad(It can be messy so wear gloves), wash with water hose, let it dry completely, and reinstall it in the printer.
There is a switch in the door latching mechanism that is not being closed rendering the machine useless. You have to replace the door latch mechanism. Go to attached site for parts Search Over 2 1 Million Appliance Parts
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
I found it under my ink cartridges in my Canon iP2000 printer. Trying to losten it for cleaning, it came out in my hand, I washed it and replaced it with a tiny amount of glue. After resetting the program, it is working again.
