20 Most Recent Avanti W851 Top Load Washer Questions & Answers
the problem with push button washers is that the buttons can be in a partially pressed position and that causes all sorts of problems like what you describe
covered is good but a button could be partially pushed from something being placed on the cover
start from one end and press/ release all buttons to check for button problem
Avanti W851 Top... | Answered on Nov 11, 2017
If the leak is front and center under the machine, it may be a pump hose leak, but my guess is the impeller has worn through the pump case. Disconnect the power and prop the front of the machine up enough to see under the front. The pump is front and center, mounted on the front of the motor. Use a flashlight to inspect the front of the pump for a curved wear spot on the front of the pump case. If this is the problem and you want to fix it yourself, the pump is available from www.sears.com under the "parts direct" tab. If its just a hose, they are available there also. You'll need your model number, usually found at the back of the main case under the lid. If self fix is possible, here are directions to remove the outer case.
Disconnect the power cord. There is either two screws, one at each front corner, holding the control panel in place or hidden clips. 1. If you see the two screws remove them. If no screws are visible you have a clip at each front corner of the control panel. The best tool to use to unhook these clips is a putty knife. Push the putty knife between the machine top and the control panel at either outer corner. You will feel a spring tension. Push firmly, but not to forcefully toward the back. When the spring releases the corner will lift easily. Repeat at the other corner. 2. Now, if there was two screws holding the panel, remove the two screws at the top on the back of the control panel. If just clips, simply and carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the machine top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the clips at the back corners on the top and release them, once again take note to their positioning. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Make needed repair and reassemble reversing procedure. Good luck.
Avanti W851 Top... | Answered on Nov 07, 2009
There are many possible cause of a leak. If it is set to portable make sure that the faucet is off after the cycle. You also need to make sure that you are not over loading the washing machine. Please refer to owners manual how much is the capacity your washing machine can take. Drain lines is also a possibility for this leak as well as the intake inlet. If it's leaking in the center most likely the bearing have broke off and you might need a new center seal. This job requires a professional to be replaced. My advice for Avanti users is to return it and buy something else that is trusted and branded for quality and performance.
Avanti W851 Top... | Answered on May 21, 2009
they should be able to order one from any appliance pars store but if not contact avainti here ive worked for them for years most of the time if you contact them they might send you one if not they will get you one http://www.avantiproducts.com/
Avanti W851 Top... | Answered on Jan 30, 2008
Check and clean door sealing area
and door gasket.
Wipe any ice and excess moisture
from chamber.
and door gasket
https://www.beckmancoulter.com/wsrportal/techdocs?docname=B10093.pdf
Avanti Washing... | Answered on Jun 26, 2019
Avanti W851 Top Load Washer Logo
21 questions posted
Top Avanti Washing Machines Experts
Ekse
Evan Benson
Evan Benson
Archie Ferrarini
Archie Ferrarini
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Avanti Washing Machines
Most Popular Question
kenmore top loader washing machine
  • Washing Machines
