You can try to reset the calculator: In so doing the default configuration is restored. If that works for your graphs why fiddle with the setting?
Ok to reset calculator (do not worry I will tell you how to change window dimension):
Press [2nd][+] to access the (MEM)ory management.
Press [7:Reset][2:Defaults] [2:Reset]
The window dimension will be restored.
To change dimensions
In main calculator screen press the [WINDOW] function key
Enter the value of Xmin. If negative use the change sign key (-) under key 3
Enter Xmax value. Make sure that Xmin is less than Xmax.
Leave the Xscale at 1
Enter Ymin. If negative use the change (-) key
You can leave the Yscale at 1, Xres at 1.
You can change the DeltaX but if you take too small a value your graphs will take long to be drawn.
If you ever get a problem, just press the [ZOOM] function key and select [6:ZStandard] it will restore the default dimensions.
