LG WM0642H Front Load Logo
Anonymous Posted on Jul 25, 2010
I have an LG Tromm washer. I start it up it start
I have an LG Tromm washer. The model is a WM0642HW. I start it up, it starts pumping water and then stops with an LE code displayed. What is the problem?
  • Anonymous Aug 22, 2010
    It seems this time that the power went out while the washer was in cycyle. I unplugged the unit for a few minutes, plugged it back in and restarted the unit with no problems. Thank you.
Anonymous
Level 3:
President:
  • Master 1,382 Answers
  • Posted on Jul 25, 2010
Anonymous
Master
Level 3:
President:
Answers
1382
Questions
0
Helped
552378
Points
5097
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
How do I trouble shoot the error code on my LG Tromm WM0642HW, it is an upside down F and E.
could the upside down F be a lower case t. If so the error code is tE and you have a heating problem.
Lg tromm wm0642hw
I'm guessing it has a float switch that shuts the water off when its full, and if it were bad it would not stop filling. Until the float switch tells the valve to close its also is not going to tell the pump to come on.
Lg front loader will not come on
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
5helpful
When I start the washer, water seems to seep in through the back and not through the sprayers? After the cycle is finished, clothes are still dirty, as if they never washed due to lack of water entering,...
I have a (2009 )WM0642HW.The new ones don't have the Forced Water Recirculation Nozzle that's in the top of the door seal. LG quietly (discontinued) that feature. If you do see a WM0642HW with a spray nozzle in top of the door seal in a showroom somewhere, it was a WM0642HW manufactured ( assembled ) a long time ago.Currently produced WM0642HW will not have the Water Recirculation feature installed. There may still be some older version "new" WM0642HW units out there somewhere? But most of them are display models or unavailable ,and with a shorter motor warranty. 7 years instead of current 10 years on new versions of the WM0642HW.But getting back to your question, the washer fills by water entering the cylinder through the back top left side of drum as it flows from the dispenser compartment via a hose.The opening is right behind the cylinder baffels location. It has no fill nozzle at the front gasket edge like some other brands have. My washer did not clean well at all with full loads. Only after i turned the water level switch under the top lid "clockwise" a half turn ,does it now fill up to the bottom of the door rubber seal.My clothing now tumbles in a pool of water instead of a WICK WATER RUB WASH that it was doing previously. It's a 100 times better with the few gallons of extra water inside, BELIEVE ME. What i say is from experience with this exact model.Turn up the water level so it can tumble in some water. TRUST ME ON THIS ONE! You'll have nothing but grief until you've had enough and have the desire to turn it up alittle.Just have it set to fill to the bottom of the door gasket.Everything will be saturated at the start of the wash and not towards the end of the wash segment.
7helpful
4answers
LG Tromm WM0642HW washer leaking water!
I have the same problem - just a small amount of water leaking out from under the machine. I removed the top cover and found one of the water lines rubs on the vent tube and has wore completely through. Should be an easy fix, as the line runs from the #2 spigot on the water inlet to the detergent box - both connections are right on top.
1helpful
Tromm washer full of water
You have a jammed drain pump and will require the pump to be removed and cleaned out.  You will need to call a qualified LG technician to resolve this problem.
LG WM0642HW
I had the same problem. LG said that the liquid bleach needs to be diluted. 50% water, 50% bleach. Straight bleach it too thick.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
