I am in the bronx, in my coop,, in a 13 x16 room. i have my unit on high with the thermostat at 75 but can only achieve 84-85 after more than 3 hours. all potential air leaks have been taped over. what are the potential problems that i may be having
Don't turn it up but turn it down. I have mine set at 61 degrees, the point is that you want it to get cooler not warmer. Sometimes I have it set at 68.
You may have a dirty condensor coil its the coil near where the warm air blows out or maybe a dirty evaporator coil its where the air gets sucked in check both of them and then see whats the air temp going into the evaporator and the temp. coming out of the vents that blow cold air the diffrence should be about 15 - 20 deg f let me know what the temps are ...but first clean the filter and both coils
SOURCE: unit not blowing cold air
you have a slow leak in your refrigerant and need to find the leak. you will have to get an AC repairman to come to your house and check it for leaks and fix the problem.
