SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: washing machine spring who do i attach it to the drum
if you have a screwdriver you can put in on the drum first the use the screwdriver to pull it up yo hook to the tub like a kind of prybar effect.
SOURCE: The rubber seal kenmore 3.8 cu ft he3t king size capacity
Our rubber seal was torn and we had a Sears repairman replace it - he said it required a special tool to install it (which he didn't have) but through some long and physical process, he was finally able to get it on.
SOURCE: kenmore top load washer 92573210
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Good Afternoon, Jataw42:
A leak from the front means a problem at the pump, or in the attached hoses. A large leak means a hose has to be replaced, and a small leak means the pump has to be replaced.
Both are simple fixes, and these guys have everything you need. Here are the parts:
#904568 for the drain hose from the pump and #1304058 from the tub to the pump.
These are here: http://www.repairclinic.com/Kenmore-Washing-Machine-Hose-Tube-Or-Fittings-Parts?s=b6a11c23p
The pump can be found here:
http://www.repairclinic.com/Kenmore-Washing-Machine-Pump-Parts
and the video instructions are great.
Good Luck to you!
Chr
