Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
