Nextar MA791 MP3 Player Logo
Melba Grady Posted on Jun 30, 2010
Will not charge
My mp3 player will not charge. I have charged all night and day and the battery will not charge or hold charge
Scott Buttrey
Level 1:
New Friend:
  • Contributor 34 Answers
  • Posted on Jun 30, 2010
Scott Buttrey
Contributor
Level 1:
New Friend:
Answers
34
Questions
0
Helped
50291
Points
78
There is a problem with one of 3 things here: The USB cable for charging, the AC adapter for charging, or MOST LIKELY the battery. The warranty should cover this. Call customer service and tell them your situation.
2helpful
Sony walkman Sony Walkman Bean NW-E305 (512 MB) MP3 Player won`t charge
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
I purchased a Coby MP826 4G MP3 player. It was working fine for the first day. Then when I had to charge the battery, it will not keep a charge. I followed the direction from the manual. When the unit...
90 day warrenty. I would return it. I just opened mine last night, and was up all night reading and applying. I am noticing some sketchy stuff with it however... I will play it out.
Will not hold a charge
Check when the adapter is plugged if the battery is charging correctly and if it charges to the full. Leave it one for about a day and check if charged , Now check the time it works ,till you fully discharge and repeat the process.
But if the battery is not holding charge, try for final with your carr charger or one from a friend beffroe wee can fully confirm the battery is faulty . Replace ONLY with the original from the dealer with the warrranty.
helpful I hope. Good day
2answers
Battery doesn't hold a charge - 1 hr play from the start - even thought I have charged up to 5 hours
How old is it ?? Try and charge it over night-- It should operate longer than 1 hr. Maybe bring it back for exchange.. ?
When charged V2 does'nt hold charge for long.
Hi.
Most likely this kind of problems occurs when the battery is exhausted after a long time of using it.
because even intergrated (rechargeable) Batteries Wont Last forever. the chemical substances(lithium-ion) in it Drains after a period of charging/discharging(using the device).
Solution:
if you have a common Mp3 player, You can purchase a new fresh battery and replace it. its quick and easy.
i can instruct you if you want so.
First check ebay for the exact same battery that you have inside you Mp3 Player.
Learn More about Lithuim-Ion Batteries on HowStuffWorks.com
Good Luck
Thank You.
1helpful
Hello, I just bought a new etec mp3 player
I've had units that took overnight , and the next day read (almost fully charged. Your not tring to charge it from the laptop battery are you....No I didn't think so. Give it a night and see what happens.
Not holding a charge
You might need a new USB cable. the one you have could have a short thats keeping it from charging.
1helpful
3answers
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
MP3 player
I think it over charged. I left it on all day. When I returned home it was turned off. Before when I tried to turn it off it wouldn't. I turned it back on and it was fine, but the battery was very low. I charged it for a smaller amount of time. It is now fine and working like normal!
Thank you,
Fixya.com
Will not charge.
turn it on then charge it
Top Nextar Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Grubhead
Grubhead
Vinho Xie
Vinho Xie
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
