20 Most Recent
Sony Walkman Bean NW-E305 MP3 Player Questions & Answers
Sony walkman Sony Walkman Bean NW-E305 (512 MB)
Good morning, afternoon, evening or night; whatever time of day you are reading this solution post. Thank you for choosing FixYa to assist you with your problem. Your Sony Walkman Bean NW-E305 (512 MB) MP3 Player won't charge properly? Well Danish, we must use a method called troubeshooting to figure out and solve this situation. There are several reasons why this player may not be charging properly. The cause is either coming from the battery inside of your MP3 Player, a bad or faulty USB cable connection, or something (software) isn't installed correctly. Let's look at the first cause- The battery. The battery life may be gone. If it is, you will need to replace it if possible. Your device takes a
My mp3 doesn't work
A few options, one is that you deleted system files when deleting mp3's and now its inoperable. Sorry, can't really help you on that one.
another option is that you're just not using the sony software to put songs in the player. song will transfer, but the player won't know what to do with it.
I heard that apart from the sonic stage software, there's another simpler one (minus some BS) than the sonic, on the sony site.
Good luck
Sony Bean 1gb "Format Error"
I have the solution. Push the menu button (the one ne with the file folder) until "search" is displayed. push the down arrow key on the jog button,10 times, until "advanced menu" is displayed. Pushe the right button on the jog until "format" is displayed. Use the jog buttons until "format ok" is displayed. Then push the play button and the problem is sorted. Good luck.
Hold on and off is not working
Hold switch operates by sliding its cover little bit and if you slide cover all the way, usb port will pop out.
Slide cover few times that might fix stuck hold switch inside.
Hop this info will help you.
Thanks
How to add music
You can add music files in Sony NW-E305 mp3 player through Sonic Stage software only.
Click
Sony Support to download Sonic Stage software, install it in computer and transfer mp3 files in player.
Thanks.
Wont turn on
Look in the area of the USB plug, in there is a small hole that a paper clip will fit into. This is a rest button, try and rest the player, it will not loose any music, but it will cause a first boot.
My walkman bean player shows a message CANNOT PLAY
if it happens with one single song it's because the file type is not formatted, you'll need to convert it (try mp3 :)
if it happens with all of your songs first try checking their type
if it's okay, try formatting your walkman and putting new songs
