HP Support > Pavilion a1600n desktop computer > Motherboard Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3245022
Scroll down the page to the illustration, and photo of the Pavilion a1600n motherboard.
On the motherboard illustration where it states DDR2 XMM1 (64 bit ,240-pin module), and DDR2 XMM2 (64 bit ,240-pin module), is where the two 1GB ram memory modules go.
On the motherboard photo, it is the two Blue in color ram memory slots.
The 512MB ram memory modules go into the Black ram memory slots.
[DDR2 XMM3, and DDR2 XMM4]
The Blue ram memory slots are one Channel. (Channel 1)
The Black ram memory slots are the second Channel.
(Channel 2)
You want to keep LIKE ram memory modules in the same Channel.
If you are having problems with the PNY ram memory modules, tell me what the manufacturer code is on them.
(Or if you bought them off of a website, see if you can copy and paste the link in a Comment. Believe upper right of your page.
FixYa is constantly undergoing changes to improve the website, is why I indicate that)
You need low density, unbuffered ram memory, DDR2 Sdram ram memory.
[DDR2 at either 533MegaHertz, or you can also use DDR2 at 667MHz.
PC2-4200 and PC2-5300 respectively ]
Don't try out any high performance ram memory is my recommendation, because the Voltage required by the ram memory, may not meet the factory default voltages that are preset in your computer.
[Factory Voltage default setting for ram memory for your motherboard, is set at 1.8 Volts.
Some high performance DDR2 ram memory requires 2.0 Volts, 2.1 Volts, or even higher ]
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Regards.
