You should not have a problem doing that. Your motherboard has a PCI Express X16 slot available. If you have problems when running intensive gaming then you may need to upgrade your PSU to a higher watttage. The 9800 GT is very power hungry. One problem you may have is that if your computer is a HP Slimline there might not be enough room inside the case for that card and you might need a low profile graphics card.
I investigate the vidoe card and would caution you to put that into you computer for the following reasons:
1. Power supply
Make sure you have at least a 500 Watt power supply so your system will be able to have enough power for the rest of the machine. Most cards have pci-e power connectors most cards have two connectors, So you need at least 1 of those for your motherboard to run your pci-e slots or if its dual core or 4 cores ect ect.
Overloading a power supply can result into malfuction or early death of the power supply.
160 watts is what the card may need I seen them at 240 watss just for the card alone. BE careful.. Just because it has a pci-e slot does not mean it will work out the box.
Just go the site of your system manufacture. Once there enter the model number of the system then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model
f it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of drivers issue
Depend on wich operating system you have, but always is good to have the latest drivers.
You should try this one:
Driver Version :266.58Release Date:01/18/2011WHQL Certified :YES
Hello ognetpc, did you install 32-bit or 64-bit video drivers ? Example if you have windows 7 64-bit you must install 64-bit video driver, because nvidia 32-bit video driver will not work properly. I found latest drivers for you video card. Click save driver to your computer, install the driver, don't forget to restart the computer. Here is the link.
Copy and paste link into your browser and press enter.
Buy a ECS N9800GTE-512MX-F GeForce 9800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card it can be gotten at newegg.com for $89 it will handle anything you throw at it. http://www.newegg.com/Product/Product.aspx?Item=N82E16814134066
Since you didn't have any problem before the update, you could flash the BIOS (revert to it's original state) by shutting down, disconnecting all power (battery for laptops), then removing the CMOS battery for 5 or 10 minutes. Replace the battery, reconnect, then boot and your BIOS should flash and return to it's initial revision and default settings.
I've got good news for you! Your Presario's motherboard only supports Supports PCI Express x16 graphics cards, and your GeForce 8600 GT is a PCI Express x16 graphics card.
However, I'm a bit concerned about the graphics card being 1gb? Both Nvidia's 8600GT and 8600GTS came out with only 256mb GDDR3 memory on them. Are you sure you have the right card?
But, if you have one with 1gb, the motherboard won't care, it's the graphics card that actually, will either work all 1gb, or only the 256mb if it's been changed.
Good Luck to you, and my answer is as long as it's a PCI Express X16 card, Yes, GO FOR IT!
Don't forget the leave a rating based on my solution.
EVERY MOBILE REQURES ITS OWN KIND OF THEMES. YOU CAN FIND BEST THEMES FOR YOUR MOBILE MODEL ON WWW.ZEDGE.NET THIS SITE IS VERY GOOD AND GIVES FREE DOWNLOADS FOR PICTURES, THEMES, RINGTONES.
